vcMatrixListProperty
Typed property that holds a list of values.
Parent: vcProperty
TypevcListPropertyTypeRGets the property type.
Valuelist[vcMatrix]RWGets or sets the property value.
waitForobjectList[vcMatrix] OR None value,
waitForNotobjectList[vcMatrix] OR None value,
